DMX Settings
The DMX Settings Menu manages the DMX interfaces attached to the console or PC.
Local DMX Menu
The Local DMX Menu is new to 4.8 and replaces the previous USB2DMX Menu for assigning universes to local attached DMX ports.
This includes the following devices:
- NX4 (4 Local Outputs)
- NX2/NX-Wing (4 Local Outputs)
- NX1 (4 Local Outputs)
- NX-P (4 Local Outputs)
- NX-Touch (1 Local Output)
- NX-DMX (2 Local Outputs)
- For a complete list of supported local DMX devices, including legacy devices, please see our license matrix
From this menu you can:
- Name Devices
- Assign the DMX port as an Input or Output
- Assign the DMX Universe
- Change the Wing ID's
Timings
Using the Timings settings, you can modify the DMX timings that ONYX transmits per universe.
Warning! Changing DMX timings may cause DMX communication to malfunction or even damage connected devices. Do not modify these settings unless you absolutely understand what you are doing!
