Deleting Elements from the 2D Plan
If you need to delete elements from the 2D Plan View, you'll first need to enter Edit mode, if you are not already there.
Enter "Edit Mode" by pressing the triangle icon labeled Live Mode:
Now, simply select the elements you wish to delete, and press the Delete icon:
You'll then need to confirm the deletion, or you may edit and command or cancel:
