NDI Settings
The NDI protocol receives networked video into Onyx for use in Dylos.
Settings
| Option | Description |
|  | Shows the current version of NDI installed and trademark information. |
|  | Setting that allows for Local NDI Sources to be accepted. |
|  | Select what interface Onyx should enable NDI on. It can also be set from the Interfaces menu. (Note: this list will change depending on the network interfaces attached to your system) |
Nodes
The Nodes menu allows an NDI node on the network to be enabled or disabled.
When enabled, Onyx will use the Node as an NDI input; disabled NDI nodes will be ignored.
Input Streams
A single NDI node may have multiple streams; this is where a stream can be enabled and configured.
|  | Sets if an NDI Stream should be received or ignored. *Enabling an NDI stream consumes considerable resources (CPU and network). It is good practice to disable unused streams. |
|  | General Stream information
 Stream Name: Name of the NDI Stream. Node Name: Name of the NDI Node on the network sending the stream. URL: IP address and port of the sending NDI Node. |
|  | Jitter Reduction
 Low Latency: Onyx will prioritize Lower Latency processing. Smooth Playback: Onyx will prioritize Smoother Playback, which may add additional latency. |
|  | Video Stream Information
 Resolution: Incoming video stream resolution. Framerate: Incoming video stream framerate. Alpha: Does the incoming video stream have an Alpha layer? Interlaced: Is the incoming video stream interlaced? |
|  | Audio Properties
 Channel Count: Displays how many audio channels are in the incoming NDI stream. Sample Rate: Displays the sample rate of the incoming audio stream. |
