Live Programming
If you change the "Live Time" parameter in the Rate section of the encoders, any changes you make will appear on stage over the selected Live Time.
For example, if you have have selected your Color Chorus 72, and press FULL they will fade to full in whatever time the Live Time is set to. This is useful for making changes on the fly during a performance.
Not only that, but if you use Blind, you can enable/disable your entire programmer at the Live Time. Pressing will enable/disable at the time set as the live time. This can be very powerful when punting lights live!
Learn more about the other timing options available in this window here: Changing Global Cue Timing.
