VU Input Processor
VU Input processors create a Volume Unit (VU) Meter input source from an NDI stream, Audio Input, or Input Slot. This can be used to apply and set input gates and input gain.
|  | VU MeterCreates a VU Meter from an audio source to set level gates
Creating a VU Input Processor
If using a VU Input Processor with an NDI Source, you must first set up NDI.
If using a VU Input Processor with an Audio Source, you must first set up an Audio Interface.
- Select the  Tab at the bottom of the window:
-  Select  under Processor.
- Select the Source
Editing a VU Input Processor
- To edit a VU Input Processor, right-click on or hold  and select an existing VU Input Processor.
      From the menu below, you can change the properties of the VU Input Processor.
|  | Preview
|  | PropertiesActive/Inactive State: Toggles the state of the VU Input Processor between Active and Inactive. * The “Inactive” state helps preserve resources on an overloaded system.*
 Change Input: Used to select a different source input for this VU Input Processor. Fixture Selection State: Select the VU Input Processor as a fixture for making changes using the Channel visualizer (CV) |
|  | This Selects if the changes should be made to the default properties of the VU Input Processor or put into the programmer like if editing a fixture. Used for changing the default state of this VU Input Processor Used for temporary changes recorded into a cue. |
|  | Output: Sets the Output level of the VU Input Processor *A value of zero translates to an output of transparent black.
 Input Gate: Sets an Audio Input Gate on the incoming audio level of VU Input Processor Input Gain: Sets the Gain level of Audio input of the VU Input Processor
 Opacity Level: Sets the Opacity level of the VU Input Processor for when used as Media Content.
|  | GoboVisualizer Mode: Sets VU visulizer mode between Needle and Bar. |
