Waveform Input Processor
Waveform Input Processor creates a dynamic visual waveform of the inputted audio source to be used as a media source inside of Dylos. Waveform Input Processors can use audio from an NDI audio stream, Audio Input, or another Input Slot.
|  | WaveformCreates a visual Waveform from selected audio input source
Creating a Waveform Input Processor
If using a Waveform Input Processor with an NDI Source, you must first set up NDI.
If using a Waveform Input Processor with an Audio Source, you must first set up an Audio Interface.
- Select the  Tab at the bottom of the window:
-  Select  under Processor.
- Select the Source
Editing a Waveform Input Processor
- To edit a Waveform Input Processor, right-click on or hold  and select an existing Waveform Input Processor.
      From the menu below, you can change the properties of the Waveform Input Processor.
|  | Preview
|  | PropertiesActive/Inactive State: Toggles the state of the Waveform Input Processor between Active and Inactive. * The “Inactive” state helps preserve resources on an overloaded system.*
 Change Input: Used to select a different source input for this Waveform Input Processor. Fixture Selection State: Select the Waveform Input Processor as a fixture for making changes using the Channel visualizer (CV) |
|  | This Selects if the changes should be made to the default properties of the Waveform Input Processor or put into the programmer like if editing a fixture. Used for changing the default state of this Waveform Input Processor. Used for temporary changes recorded into a cue. |
|  | Output: Sets the Output level of the Waveform Input Processor *A value of zero translates to an output of transparent black.
 Input Gate: Sets an Audio Input Gate on the incoming audio level of Waveform Input Processor Input Gain: Sets the Gain level of Audio input of the Waveform Input Processor
 Opacity Level: Sets the Opacity level of the Waveform Input Processor when used as Media Content.
 Palette Subtract: Sets the Palette brightness between Subtractive or Additive. Palette Inverse: Sets the palette contrast level or inverts it. |
|  | BeamWave Rescaling: Sets the scale of the waveform Wave Zoom: Sets the zoom level of the wave within the canvas Waveform Width: Sets the vertical width of the wave within the canvas. Palette Zoom: Sets the zoom level of the sample point for the pallete. |
