Waveform Input Processor
Waveform Input Processor creates a dynamic visual waveform of the inputted audio source to be used as a media source inside of Dylos. Waveform Input Processors can use audio from an NDI audio stream, Audio Input, or another Input Slot.
Waveform
Creates a visual Waveform from selected audio input source
Creating a Waveform Input Processor
If using a Waveform Input Processor with an NDI Source, you must first set up NDI.
If using a Waveform Input Processor with an Audio Source, you must first set up an Audio Interface.
  1. Navigate to the Library view, button 5, on the default sidebar of the "Compose" workspace.
  2. Select the Input Source Tab at the bottom of the window:
  3. All slots will be blank if you're starting from scratch. To create one, Right-click or hold EDIT and press an empty slot.
  4. Select Create Input Source...
  5.  Select Waveform under Processor.
  6. Select the desired Source Type
  7. Select the Source
  8. Press OK
Editing a Waveform Input Processor
  1. To edit a Waveform Input Processor, right-click on or hold Edit and select an existing Waveform Input Processor.
  2. Select Show Details
  3. From the menu below, you can change the properties of the Waveform Input Processor.
Control Description
  1. Visualizer: Shows a visual representation of the input processor.
  2. Audio Input Meter: Shows a meter of the incoming audio signal or the embedded NDI audio stream.
  3. Pallet Mapping: Shows the generated pallet for use with a dynamic pallet.
Properties
Active/Inactive State: Toggles the state of the Waveform Input Processor between Active and Inactive.
* The “Inactive” state helps preserve resources on an overloaded system.*
Change Input: Used to select a different source input for this Waveform Input Processor.
Fixture Selection State: Select the Waveform Input Processor as a fixture for making changes using the Channel visualizer (CV)
This Selects if the changes should be made to the default properties of the Waveform Input Processor or put into the programmer like if editing a fixture.
Defaults: Used for changing the default state of this Waveform Input Processor.
Programmer: Used for temporary changes recorded into a cue.
Output: Sets the Output level of the Waveform Input Processor
*A value of zero translates to an output of transparent black.
Input Gate: Sets an Audio Input Gate on the incoming audio level of Waveform Input Processor
Input Gain: Sets the Gain level of Audio input of the Waveform Input Processor
Opacity Level: Sets the Opacity level of the Waveform Input Processor when used as Media Content.
  • Full: All transparent areas of the input content are shown in opaque black (e.g. useful if you want to map a color palette on it)
  • Zero: Transparent areas stay transparent
Palette Subtract: Sets the Palette brightness between Subtractive or Additive.
Palette Inverse: Sets the palette contrast level or inverts it.
Beam
Wave Rescaling: Sets the scale of the waveform
Wave Zoom: Sets the zoom level of the wave within the canvas
Waveform Width: Sets the vertical width of the wave within the canvas.
Palette Zoom: Sets the zoom level of the sample point for the pallete.
