Onyx 4.32 brings powerful new tools for even greater control and flexibility in your lighting workflow. The introduction of SKIP cues and parameter release within cues gives you precision over tracking like never before. A new LTC Audio Timecode Input Processor expands synchronization options, while improved FADE/DELAY/WEIGHT editing streamlines programming.
This update also introduces a brand-new weight system, allowing dynamic control over transitions by blending between direct cue and Dylos output per parameter. Additionally, new virtual gobo mapping unlocks advanced texture effects, and a dual fixture group mapping mask provides more flexible fixture control. Improved show backup naming ensures better organization, while AnyDesk remote support, expanded Focusrite ASIO driver compatibility, and numerous bug fixes enhance overall system stability.
Discover the latest enhancements and take your show to the next level!
Feature Overview Video
Release Notes
Onyx 4.31.1292 (Feb 10, 2025)
New Features
- ONYX-939 Added LTC Audio timecode input processor
- ONYX-1109 Added AnyDesk to diagnostic tools for remote support
- Added "Release" value in cues to release a channel from tracking through subsequent cues
- Added new "Skip" cue option (default ON) for genuine cue-only behavior (values previous cue tracked through in next cue rather than hard coded value duplication in next cue)
- Added dual fixture group mapping mask with logical combination options
- Added gobo pixel mapping mode
- Added weight sub channels to cross fade direct <-> pixel-mapped output per parameter
- Added fade/delay/weight editing modes behind double click on LINK button
- Added fixture group mapping mask
- Added palette support to effect slots
Updates / Improvements
- ONYX-1025 Improved parameter encoder behavior and range locking
- ONYX-74 Improved show backup naming (BeforeCreate/Load/Optimize/Upgrade now became a prefix for the file name that includes show name, time and build)
- ONYX-1025 Improved FADE/DELAY/WEIGHT editing mode toggling
- ONYX-1112 Allow install of latest Focusrite ASIO driver installers (including 4th generation); 3rd party (ASIO) packages can now also be uninstalled
- Improved gobo pixel mapping mode
- Improved consistency of using channel and parameter group buttons with CLEAR/DEFAULT/LOAD/SET SELECTION on command line
Fixes
- ONYX-1088 Fixed Patch help
- ONYX-1094 Fixed [GROUP] [ENTER] not pulling any fixture, that is not at zero intensity, into programmer; [GROUP] [FULL] will now work as [GROUP] [@] [FULL]
- ONYX-1115 Fixed DyLOS color palette selection and preview issues
- ONYX-1037 Visual and recording fixes for parameter releases in cues
- ONYX-1112 Fixed uninstall of Focusrite packages
- ONYX-1065 Fixed intensity output in cuelist ID 10,000 and up
- ONYX-1116 Fixed software grand master (in title bar)
- ONYX-1124 Fixed "Division by zero" error when attempting to scroll using 2 touch points
- Fixed WEIGHT not being applied to Pan/Tilt and "random" other values
- Fixed CLEAR/DEFAULT/LOAD through right-click on parameter groups
- Fixed FADE/DELAY OUT being applied when providing fanning value for IN
- Fixed CLEAR SELECTION on programmer groups not considering BASE/FX/TIME filters
- Fixed CLEAR FIXTURE
- Fixes in weight tracking; Fixes in Weight clearing through filter
- Fixed CLEAR on parameter group while in FADE/DELAY/WEIGHT editing mode
Miscellaneous
ONYX-1075, ONYX-1084, ONYX-1121, ONYX-1136, ONYX-1136, ONYX-1109, ONYX-1075, ONYX-1123, ONYX-1130, ONYX-1133
